Abbey Bike Tools Bottom Bracket Socket Tool
| Article number: | 005-05-01 |
Abbey Bike Tools Bottom Bracket Socket Tools are precision CNC machined in the USA from solid 7075 aluminum billet for accurate engagement with modern bottom bracket cups. Designed for workshop installation and removal, these sockets feature finger splines that make it easier to hand start threaded cups without damaging new parts.
Available in both dual-sided and single-sided versions, the Abbey bottom bracket socket range covers a wide variety of external and specialty bottom bracket standards. Each socket is compatible with a 3/8 in square drive, making it easy to integrate into existing workshop tool setups. For preload adjustment on Shimano systems, pair these sockets with the Abbey Shimano Crank Pre Load Tool.
Why Use Abbey Bottom Bracket Socket Tools
Bottom bracket installation and removal require accurate tool engagement to avoid damaging cups, finishes, or splines. Abbey bottom bracket sockets are designed for precise fit, clean engagement, and long-term workshop durability across a wide range of threaded and specialty bottom bracket standards.
- Designed for bottom bracket installation and removal
- Precision CNC machined from 7075 aluminum billet
- Finger splines help hand start threaded cups cleanly
- Available in multiple socket standards for modern bottom brackets
- Compatible with 3/8 in square drive tools
- Made in the USA
- Professional workshop bottom bracket service
- Installing and removing threaded bottom bracket cups
- Mechanics working across multiple bottom bracket standards
- Reducing cup damage during installation and removal
Available Socket Options
Dual-Sided
Dura-Ace / Ultegra
Compatible with Shimano Dura-Ace 9000 and newer, Ultegra 6800 and newer, 105 5800 and newer, and current XTR bottom bracket shell types.
Single-Sided
Hollowtech II
Compatible with outboard bearing cups not covered by the dual-sided Shimano socket, including Campagnolo, SRAM, FSA, and older Shimano systems.
THM
Compatible with THM bottom brackets except the new internal T47.
BSA30 12 Notch
Compatible with SRAM DUB, Race Face Cinch, Rotor BSA 30, and Zipp Vuma Quad bottom brackets. Not compatible with Praxis, TorqTite, or Hope. (46 mm x 24 notch)
BSA30 16 Notch
Compatible with FSA 386-EVO cups and some Wheels Mfg cups. Not compatible with Praxis, TorqTite, or Hope. (44 mm x 16 notch)
Praxis
Compatible with Praxis M30, M30 Thru, and Conversion bottom brackets except the new internal T47.
TorqTite
Compatible with TorqTite BSA30 bottom brackets.
Colnago
Compatible with Colnago 30 mm bottom brackets.
Chris King
Compatible with Chris King ThreadFit 30 and ThreadFit T47 bottom brackets.
Pairs Well With
For Shimano crank preload adjustment, pair these sockets with the Abbey Shimano Crank Pre Load Tool. For broader workshop setup and fastener service, these sockets also fit well alongside the Abbey T-Handle Tool.
