Carbon-Ti Centerlock X-Rotor SteelCarbon 3
Article number: | 007-01-02 |
The X-Rotor SteelCarbon 3, an evolution of the SteelCarbon 2, is a high-performance Centerlock disc. With a superlight semi-floating structure, steel braking surface, carbon fiber inner body, Al7075 Adapter, and laser-engraved titanium plate, it features Grade 5 titanium rivets and CNC-machined rounded edges meeting UCI regulations. The 1.8mm special steel track enhances braking, heat dissipation, and pad wear. Precision-crafted in Italy, it's compatible with 12, 15, or 20mm thru-axles, fits 160mm pads (preferably organic), and excelled in extreme conditions with the UAE Team Emirates during the Giro d'Italia. It's also usable as a 6-bolt rotor, showcasing precision and artisanal craftsmanship for top-tier performance.
Fits | 140 mm | 160 mm | 180 mm |
Total Weight | ~95g | ~106g | ~125g |
Rotor | ~68g | ~80g | ~98g |
Lockring Adapter | ~25g | ||
Material | |||
Rotor | Stainless Steel / Grade 5 Titanium / Carbon Fiber | ||
Lockring Adapter | 7075 Aluminum / Titanium |
