Carbon-Ti X-Lock 12 mm Front Thru Axle
Article number: | 08-04-01 |
With industry standards shifting from quick releases to though axles, having high quality aftermarket options to precision tune your build becomes a welcome luxury. Luckily, Carbon-Ti has produced some incredibly handsome front thru axles designed to work with current standards used by various manufacturers. Ideal for cyclists looking to shed grams while also maintaining a minimalist aesthetic, the Carbon-Ti X-Lock front thru axle is sure to find a home on many elite builds.
The Carbon-Ti X-Lock Front thru axle is proudly made in Italy.
Material | 7075 aluminum |
Tool Fitting | 5mm Hex |
Hub Compatibility | TA 12 x 100 |
Recommended Torque | 10Nm |
Model | Interface | Length | Thread Pitch | Thread Length | Weight |
X-12 Road | Tapered | 117 mm | 12 x 1.0 mm | 14 mm | 26g |
12 x 119 mm Road | Flat | 119 mm | 12 x 1.5 mm | 12 mm | 23g |
12 x 123 mm Road | Flat | 123 mm | 12 x 1.75 mm | 12 mm | 25g |
12 x 125 mm Road | Flat | 125 mm | 12 x 1.5 mm | 12 mm | 24g |
