Carbon-Ti X-Lock EVO 12 mm Front Thru Axle
| Article number: | 008-02-05 |
True to the quality we have come to expect from Carbon-Ti, these thru axles are excellently stiff, with variable thickness. There is a 6mm hex fitting for safe and secure closing(hex key not provided), as well as beautifully laser etched graphics.
These axles are available in several of Carbon-Ti's beautiful anodized hues.
All Carbon-Ti products are proudly designed and manufactured in Italy.
| Model | Interface | Length | Pitch | Thread Length | Weight |
| X-12 Road | Tapered | 117 mm | 12 x 1.0 mm | 14 mm | ~22g |
| 120 mm Road | Flat | 120 mm | 12 x 1.5 mm | 13 mm | ~22g |
| 125 mm Road | Flat | 125 mm | 12 x 1.5 mm | 13 mm | ~24g |
| 122 mm Road | Flat | 122 mm | 12 x 1.75 mm | 10.5 mm | ~24g |
| Material | 7075 Aluminum | ||||
| Tool Fitting | 6 mm Hex | ||||
| Hub Compatibility | T/A 12 x 100 | ||||
| Recommended Torque | 10Nm | ||||
Forks Compatibility List:
X-Lock 12x1.0 X-12 (117mm)
- Specialized
- Aethos (2021)
- Crux S-Works (2019-2021)
- Crux Disc (2019-2021)
- Tarmac SL7 & SL6 S-Works Disc (2019-2021)
- Tarmac SL7 & SL6 Pro, Expert, Comp Disc (2019-2021)
- Venge S-Works Disc (2019-2020)
- Venge Pro, Expert, Comp Disc (2019-2020)
X-Lock 120 mm Road
- Bianchi
- Aria (2020-2021)
- Specialissima (2021)
- XR4 Disc (2021)
- Cinelli
- Nemo Tig Gravel (2021)
- Pressure (2021)
- ENVE
- Carbon Disc Fork
- Pinarello
- Disc (2019)
- Scott
- Addict Gravel (2020-2021)
- Foil Disc (2018-2019)
- Ridley
- Noah
X-Lock 125 mm Road
- Bianchi
- Zolder Pro (2019)
- Cannondale
- Synapse Disc (2018)
- Parlee
- Altum Disc (2018-)
- Chebacco (2018-)
- Z-Zero Disc/XD (2018-)
- TTiR Disc (2018-)
- Scott
- Addict (2020-2021)
X-Lock 122 mm Road
- Trek
- Emonda Disc (2019-2021)
- Madone Disc (2019-2021)
