ControlTech TiMania Titanium Road Handlebar
| Article number: | 007-02-06 |
The TiMania road handlebar from ControlTech blends the best of classic and modern materials for a unique ride experience. Its titanium clamp captures the timeless aesthetic and forgiving ride quality of this elegant metal. Unidirectional carbon fiber drop bars provide modern stiffness and weight savings where it matters most. The result is a handlebar with the beautiful styling and ride feel of titanium and the performance benefits of carbon. With options from 40 to 44cm and weighing from 226 to 244g, the TiMania bar is ideal for discerning riders seeking a sophisticated blend of tradition and technology. Its elegant materials and refined design embody the ControlTech commitment to innovation, performance, and lasting quality.
To ensure optimal installation of your ControlTech TiMania road handlebar, we recommend professional installation by a competent mechanic. Use a calibrated torque wrench set at a maximum of 7 Nm for tightening. Prior to installation, thoroughly clean the stem and bar interface, and apply appropriate grease to the stem bolts.
| 40 cm | 42 cm | 44 cm | |
| Weight | ~226g | ~235g | ~244g |
| Reach | 75 mm | ||
| Drop | 130 mm | ||
| Flare | 0° | ||
| Stem Clamp Diameter | 31.8 mm | ||
| Material | UD Carbon / 6AL4V Titanium | ||
| Internal Routing | No | ||
| Di2 Compatible | No | ||
