$160.00
* Unit price: $160.00 /
The ControlTech Tux seatpost delivers lightweight performance and adjustability for discerning riders. With a carbon fiber construction that shaves weight without sacrificing strength, the Tux weighs in at around ~200g depending on length and offset. The sleek matte black finish and half centimeter height markings add style and ensure precise saddle positioning. The two-bolt head enables easy installation and micro-adjustments, fitting both round and ovalized 7mm rails. With quality craftsmanship and thoughtful engineering, the Tux seatpost provides exceptional value, comfort, and efficiency.
We recommend having your Tux seatpost installed by a skilled mechanic using a properly calibrated torque wrench. It is imperative that all torque ratings for your seat collar and frame be followed while installing. We recommend the use of an anti-slip compound such as Park Tool's Supergrip Compound on the seatpost, decreasing the chance of the seatpost slipping, and a light coating of a quality bicycle grease, such as ProGold's EPX Grease, on the bolt threads for all carbon fiber seatposts.
Weight 27.2 mm 31.6 mm
0 mm Offset ~194g ~202g
10 mm Offset ~199g ~206g
Length 350 mm / 400 mm
Max Torque 10Nm
Rail Compatibility 7 x 7 mm / 7 x 9 mm / 7 x 10 mm
Minimum Insertion 100 mm
Recommended Use Road / Cyclocross / Mountain
Material Post Hardware
Max Torque UD Carbon Fiber Stainless Steel
