DT Swiss 240 EXP J-Bend Disc Front Hub
$229.90
Article number: 11-05-04
Availability: In stock (2)
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The new version of the end caps simplifies the tool-free disassembly and makes maintenance easier.
Covered by a 2 year warranty against manufacturing and material defects, 240 EXP hubs offer some of the best performance in the industry.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us or submit a form for a custom wheel build.
  Centerlock 6-Bolt
Weight ~116 grams ~138 grams
Spoke Holes 24h / 28h 28h
Axle Standard 12 x 100 / 15 x 100 15 x 100
-- Wheelbuilding Dimensions --
Flange Diameter Left 44.4 mm 57.8 mm
Flange Diameter Right 44.4 mm 49.4 mm
Center to Left Flange 22.6 mm 22.3 mm
Center to Right Flange 36.2 mm 36 mm
Spoke Hole Diameter 2.55 mm
  TA 12 TA 15
Bearing Size 1526 (2) 1728 (2)
