DT Swiss 350 Road Rim Brake Front Hub
Article number: | 010-03-03 |
The DT Swiss 350 Road Front Hub delivers a balance of lightweight design, durability, and easy serviceability for road and all-road applications. Its redesigned shell and axle draw from the proven DT 240 platform, offering dependable performance at a more accessible price point. Available in J-Bend or Straight-Pull spoke configurations, it uses standard sealed cartridge bearings for straightforward maintenance and is compatible with optional ceramic bearing upgrades for reduced friction. Built for rim-brake systems, it’s a versatile choice for custom wheel builds and long-term reliability.
Lightweight, precision-machined hub shell
J-Bend and Straight-Pull spoke compatibility
Optional ceramic bearing upgrade
Rim-brake only, 5 mm × 100 mm axle standard
Tool-friendly maintenance design
2-year manufacturer warranty
WHEEL BUILDING
J-Bend | Straight-Pull | |
Weight | ~146g | ~114g |
Spoke Holes | 20h / 24h / 32h | 20h |
Axle Standard | 5 mm x 100 mm | |
Bearings Size | 6902 - (2) | |
Brake Interface | Rim Brake Only | |
-- Wheel Building Dimensions -- | ||
Flange Diameter Left | 39 mm | 26.15 mm |
Flange Diameter Right | 39 mm | 26.15 mm |
Center to Left Flange | 37.4 mm | 37.8 mm |
Center to Right Flange | 37.4 mm | 37.8 mm |
Spoke Hole Diameter | 2.6 mm | 2.5 mm |
Pair your front hub with the matching 350 Road Rear Hub for a complete build. For a lighter alternative, consider the 240 Road Front Hub. Upgrade performance with a Ceramic Bearings or browse Wheelbuilding Tools for maintenance.
___________________: | ________________________ |
Spoke Hole: | • 20 / 24 / 32 |
Axle Standard: | • 12 x 100 |
Hub Interface: | • Quick Release |
Brake Interface: | • Rim Brake |
Material: | • |
