DT Swiss 350 Straight-Pull Boost Disc Front Hub
Article number: | 11-03-01 |
Reliability meets simplicity, exactly according to this credo the 350 hub was developed. Designed for optimal function, the plugged construction allows easy maintenance without the need of tools.
The 350 hub line incorporates the key features of the famous DT 240 line at a more economical price. By slightly changing the manufacturing process and enlisting overseas facilities, DT is able to offer the same incredible performance for those on a budget. Utilizing common sized sealed cartridge bearings and a standard spoke hole drilling pattern, DT hubs can be serviced by any reputable shop or home mechanic with a few basic tools. For cyclists who depend on their gear lasting through the season and want peace of mind, or for those who demand the utmost of their equipment, a set of DT Swiss 350 hubs is a sound investment.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild .
Centerlock | 6-Bolt | |
Weight | ~136g | ~143g |
Bearing Size | 6902 - (2) | |
Spoke Holes | 28 | |
Axle Standard | 15 x 110mm Boost | |
--Wheelbuilding Dimensions-- | ||
Flange Diameter Left | 40.8 mm | 40.8 mm |
Flange Diameter Right | 36 mm | 36 mm |
Center to Left Flange | 27.9 mm | 28 mm |
Center to Right Flange | 40 mm | 40.2 mm |
Spoke Hole Diameter | 2.6 mm | |
Spoke Hole Offset L / R | 1.7 / 1.8 |
