DT Swiss Replacement EXP Freehub Body
| Article number: | 010-03-08 |
Replacement EXP freehubs, will not work on older DT Ratchet sytle hubs.
All freehub kits include a drive / right side end cap, they don't include both. If you need to change your hub to a different axle adapter, please order the freehub without the end cap. You can find the correct kit here.
| Campagnolo 9-12 Speed | Campy N3W | ||
| HWYABL00S7073S | 5 mm QR | HWYABL00S2993S | Thru Axle Kit |
| HWYABL00S7074S | Thru Axle Kit | HWRABL00S2321S | w/o End Caps |
| HWRABL00S4864S | w/o End Caps | ||
| Shimano Micro Spline | Shimano Mountain 10 Speed | ||
| HWYABL00S5374S | Thru Axle Kit | HWYABL00S5370S | Thru Axle Kit |
| HWRABL00S4863S | w/o End Caps | HWRABL00S3123S | w/o End Caps |
| Shimano Road 11 Speed | |||
| HWYABL00S5399S | 5 mm QR | ||
| HWYABL00S5378S | Thru Axle Kit | ||
| HWRABL00S4866S | w/o End Caps | ||
| SRAM XD | SRAM XDR | ||
| HWYABL00S5372S | Thru Axle Kit | HWYABL00S5382S | 5 mm QR |
| HWRABL00S3830S | w/o End Caps | HWYABL00S5401S | Thru Axle Kit |
| HWRABL00S4865S | w/o End Caps | ||
