EliLee X-Novanta Crank
| Article number: | 002-03-01 |
Introducing the EliLee X-Novanta Crank. Through rigorous engineering and testing this crank has been developed into one of the lightest and stiffest full carbon cranks on the market. The X-Novanta is also the first full carbon crank in production that can accomodate a spider based power meter. The direct mount set-up allows you to choose between a standard 4 or 5 bolt spider, a spider based power meter, or a direct mount chainring. The X-Novanta is available in all of the most common crank arm lengths.
Spiders are available in both aluminum and carbon options. Check them out here.
If there is a length you would like that is not listed as available, or if you have questions about power meter spider options, then contact us, and we will be happy to help you.
| Crankarms | 162.5 / 165 / 167.5 / 170 / 172.5 / 175 |
| Weight | ~282g (172.5) |
| Q-Factor | 149 mm |
| Chainline | 44.5mm |
| Axle Length | 91.5mm |
| Interface | Easton Cinch Style Direct Mount Spider |
| Spindle | 30mm Carbon |
