Fair Wheel Bikes Tubeless Tape
$14.00
Article number: 013-03-03
The Fair Wheel Bikes Tubeless Tape is a high‑adhesion rim sealing tape designed specifically for tubeless 700c / 29‑inch wheelsets. Available in a variety of widths (19 mm – 34 mm) to suit most common rims. Each roll is 10 meters long — enough to apply a single layer to four 29″ / 700c rims. Color options vary depending on stock.
Made with adhesive backing that resists tearing, sealant chemicals, and heat. Ideal for a clean, reliable tubeless setup—no fussing, no risk of leaks from improper tape adhesion.
  • Multiple widths (19–34 mm) for modern rim profiles
  • 10 m roll length—covers 4 large rims per roll
  • Strong adhesive backing designed for tubeless sealant compatibility
  • Flexible cloth construction that conforms to rim bed curves
  • Tear‑resistant bulk; resists damage during installation
Installation Tips
  1. Clean the rim bed thoroughly; remove any old tape or residue.
  2. Center the tape on the rim bed; apply under light tension to avoid wrinkles.
  3. Overlap tape by ~5–10 mm at the inside valve area.
  4. Press firmly all around with a roller or flat tool to ensure adhesion.
  5. If applying sealant, check after first ride for any seepage.
