FWB Carbon Bar Plugs
$20.00
Article number: 013-06-01
Our 100% carbon fiber bar end plugs for road bikes are manufactured using several different types of carbon fiber to produce an item that is strong, light, and durable. Most normal plastic bar end plugs are too small in diameter and too short, allowing them to fall out of your bar much too easily. The carbon plugs are longer and larger in diameter at the tab end helping them to stay where you want them....in your handlebar! The exterior dome is available in several finishing options to best match your style. Sold in pairs.
*Be gentle when installing. If you're tape is too thick we would recommend inserting less material into the bar end or trimming as pictured.
 Weight / Pair 3k Unidirectional
 Matte ~4.8g ~5g
 Gloss ~5.4g ~4.9g
 Material Carbon Fiber
