Far And Near 105 5800 Brake Hoods
$25.00
Article number: 018-03-04
Each set includes left and right hoods, meticulously designed for Shimano 105 5800 11-speed levers.
INSTALLATION
Compatibility Shimano 105 5800 Shift Levers
Weight ~49g (pair)
