$25.00
$20.00
* Unit price: $20.00 /
Article number: 026-05-06
Each set includes left and right hoods, meticulously designed for Campagnolo 11-speed Ergopower levers.
INSTALLATION
Compatibility Campagnolo 11-speed Ergopower Levers
Weight ~47g (pair)
