Far and Near Chain Deflector
$28.00
$18.20
* Unit price: $18.20 /
Article number: 018-03-02
Far and Near Chain Deflector provides a lightweight solution for improving chain retention on bikes using front derailleurs. Designed for demanding conditions such as cyclocross, gravel, and rough road riding, it helps prevent dropped chains without adding unnecessary weight.
Machined from 7075 aluminum, the deflector replaces the stock derailleur mounting hardware with a precision component that adds only ~1 gram over standard hardware. Each kit includes an anodized bolt and concave washer, while the deflector itself is available in multiple colors for a clean, integrated look.
  • Cyclocross and gravel riding where chain drops are more likely
  • Road bikes ridden on rough or variable terrain
  • Improving chain retention on front derailleur setups
  • Lightweight builds requiring minimal added hardware
  • Riders seeking a clean alternative to bulky chain catchers
Installation Notes
Install using a T25 Torx tool. The deflector mounts at the front derailleur braze-on tab, positioned between the supplied bolt and concave washer. Ensure proper front derailleur alignment during reinstallation by following manufacturer guidelines.
 Compatibility Braze-On Front Derailleur Tabs Only
 Material 7075 Aluminum
 Weight (With Hardware) ~5.6g
 Tool Interface T25 Torx
Pairs Well With
For best results, combine a properly adjusted front derailleur with a chain deflector to achieve maximum chain security and consistent shifting performance.
