Far And Near Dura Ace 7800 Brake Hoods
Article number: | 018-02-05 |
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace 10-speed levers.
INSTALLATION
Compatibility | Shimano Dura-Ace 7800 Shift Levers |
Weight | ~51g (pair) |
