Far And Near Dura Ace 7800 Brake Hoods
$25.00
$20.00
* Unit price: $20.00 /
Article number: 026-03-05
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace 10-speed levers.
INSTALLATION
 Compatibility Shimano Dura-Ace 7800 Shift Levers
 Weight ~51g (pair)
