Far And Near Dura Ace 9001 Brake Hoods
Article number: | 14-04-05 |
Each set includes left and right hoods, meticulously designed for Shimano Dura-Ace 9001 11-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Dura-Ace 9000 series shift/brake levers.
Compatibility | Shimano Dura-Ace 9001 Shift Levers |
Weight | ~48g (pair) |
