Far And Near 105/Ultegra 10spd Brake Hoods
Article number: | 14-03-05 |
Availability: | In stock (5) |
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano 105 (5600), Ultegra (6600) and Ultegra SL 10-speed levers.
INSTALLATION
Compatibility | Shimano 105 (5600) / Ultegra 6600 Levers |
Weight | ~58g (pair) |
