Far And Near Ultegra R8000 Brake Hoods
Article number: | 018-01-01 |
Each set comprises two hoods, one for the left and one for the right, meticulously designed to fit Shimano Ultegra R8000 11-speed levers.
INSTALLATION
Please note that these hoods are not compatible with Shimano Ultegra (8020 / 8050 / 8070) series 11-speed shift/brake levers.
Compatibility | Shimano Ultegra R8000 Shift Levers |
Weight | ~53g (pair) |
