$490.00
Article number: 33-01-01
The Omnium's versatility is matched only by its ease of use, enabling its usefulness across a variety of cycling disciplines and scenarios. Setup is quick and easy, and requires no tools at all. The fork mount includes adapters for maximum versatility, compatible with quick release, 12 and 15mm thru bolt, and boost axle standards. The Omnium's adjustable frame design accommodates a wide range of wheel diameters and tire sizes; whether you're riding road, mountain, or cyclocross (or all three), this is the trainer for you. When not in use, the Omnium folds down to just 26" in length; and at a mere 13.8 pounds, lifting it won't require a second thought. If this weren't enough, Feedback includes a heavy duty tote bag for convenient transportation and storage.
On the Over-Drive the rear wheel rollers include an Internal Progressive Resistance unit to allow for an incredibly wide range of efforts for such a small package. The Zero-Drive offers the same minimal resistance as traditional rollers, ideal for high speed spinning or track workouts.
As with all Feedback products, the Omnium is impeccably designed and finished with high attention to detail, featuring lightweight, high strength aluminum construction. The Omnium is covered by a 3-year warranty.
If you have questions please contact us and we will assist you in selecting the trainer for your needs.
Weight
Zero-Drive - 13.3 lbs (6.03 kg)
Over-Drive - 14 lbs (6.25 kg)
Folded Dimensions
25.75″ x 7.25″ x 8″ (66 cm x 18 cm x 20 cm)
Compatible Bicycles
Road, Triathlon, Mountain, Gravel, Cyclocross
Fork/Axle Compatibility
9x100 QR; 12×100, 15×100 & 15×110 (boost) adapters included
Wheel/Tire Size Compatibility
600c – 700c, 26″-29″
Adjustable Wheel Base Range
840mm to 1203mm, optional extension sold separately
Rider weight limit
225 lbs
