$97.65
FSA's AGX components are ideal for Adventure, Gravel, and Cyclocross enthusiasts, blending advanced carbon composite and metal alloy technology with cutting-edge manufacturing. The A-Wing Pro alloy handlebar, designed for these pursuits, features flared drops for control during descents, showcasing FSA's alloy expertise. With Aerodynamic Integrated Cable Routing (ACR) and sculpted contact points for comfortable riding, it prioritizes ergonomics. The handlebar has a 121mm drop, 88mm reach, 15° outward bend, and 2.5mm rise. Finished in bead-blasted anodized black, it weighs just 296 grams (420mm version), measured from the hoods, not dropouts.
Measurements (C - C)
 Dropouts 46.8 cm 48.8 cm 50.8 cm
 Hoods 42 cm 44 cm 46 cm
 Reach 87.4 mm 88.6 mm 89.8 mm
 Weight ~296g ~304g ~313g
 Outward Bend 15 degrees
 Drop 120.7 mm
 Stem Clamp Diameter 31.8 mm
 Material Aluminum
