FSA SL-K Road Compact Carbon Handlebar
| Article number: | FitWorks |
The SL-K Compact handlebar is a top-tier choice in unidirectional carbon for competitive racing. With a shallow 125mm drop and subtle flare, its latest compact design includes a wide center section for accessories like GPS units or lights (computer mount sold separately). Stem and lever attachment points are reinforced and textured for a secure grip. Offered in four widths, including a 380mm variant for women or junior riders, it's compatible with ACR and SCR, featuring UD carbon monocoque construction. New internal cable routing options for Di2 are available. The sleek UD Carbon finish not only looks great but also reduces weight, with options weighing 205g (380mm), 210g (400mm), 215g (420mm), and 220g (440mm), measured from the dropouts, not hoods.
| Measurements (C - C) | ||||
| Dropouts | 38 cm | 40 cm | 42 cm | 44 cm |
| Hoods | 36.1 cm | 38.1 cm | 40.1 cm | 42.1 cm |
| Weight | ~205g | ~210g | ~215g | ~220g |
| Outward Bend | 4 degrees | |||
| Reach | 78 mm | |||
| Drop | 125 mm | |||
| Stem Clamp Diameter | 31.8 mm | |||
| Material | UD Carbon Monocoque | |||
