ISM PN Saddle
| Article number: | FitWorks |
The PN, Performance Narrow, saddles offer a narrow chassis, ranging from 110 - 125mm wide, allowing superb thigh and hamstring clearance and greater rider body movement around the seat.
Like all ISM saddles, the PN series is nose-less and designed to remove pressure from soft tissue, ensuring maximum blood flow, no genital numbness, and a healthier, more enjoyable ride.
| Model | Length | Width | Rails | Padding | Usage |
| 1.0 | 275 mm | 110 mm | Stainless | 25-Series Foam & Gel | Road, Triathlon, Time Trial |
| 1.1 | 275 mm | 110 mm | Steel | 40-Series Foam & Gel | Road, Triathlon, Time Trial |
| 3.0 | 255 mm | 120 mm | Stainless | 30-Series Foam | *Road, Time Trial* |
| 3.1 | 255 mm | 120 mm | Chromoly | 40-Series Foam | *Gravel, Road, Time Trial* |
| 4.0 | 255 mm | 125 mm | Stainless | 30-Series Foam | *Gravel, Road, Time Trial* |
| 4.1 | 255 mm | 125 mm | Chromoly | 40-Series Foam | *Gravel, Road* |
*This saddle is not recommended for cyclists who ride with a high seat position or those who ride very forward on the extreme front of the saddle
