KCNC Ceramic Pulley Wheel
Article number: | 023-01-05 |
KCNC's pulleys are intentionally designed with an integral amount of "float," or lateral movement. This movement allows the pulley to settle into an optimum position under each cassette cog. The result is faster, smoother shifts and a quieter drivetrain. In our experience, these are the best-shifting after market pulleys available, past or present.
Each KCNC pulley wheel is equipped with a high quality hybrid ceramic cartridge bearing. The advantages of using a ceramic bearing in the rear derailleur's pulleys are the most dramatic of any other bicycle bearing system. This is due to the high speed at which the pulleys spin - often as high as 600 RPM.
Each pulley is machined from light and strong 7075 aluminum and anodized, with laser cut logos.
Compatible with Campagnolo, SRAM (road and X-0), and Shimano 9-11spd rear derailleurs. (Campagnolo 10 speed derailleurs are equipped with 10 tooth pulleys, SRAM, Shimano, and 11 speed Campagnolo are equipped with 11 tooth pulleys).
Sold individually.
Weight | 8.5g |
Material | 7075 Aluminum |
Bearing Size | 689, Hybrid Ceramic |
Available Sizes | 10, 11, 12, 13 tooth |
Compatible Derailleurs | Shimano, Campagnolo, Sram |
