$12.00
Article number: 019-05-01
KCNC designed these bottle cage bolts sets to be versatile, light weight, and attractive. The low profile button heads are a mere 2.5 mm tall, making them compatible with nearly every available bottle cage design. The long 15 mm threads also allow these bolts to be used with frame spacers or in other situations where a longer bolt is necessary. A T25 Torx wrench is required to install or remove the bolt, and a pair of stainless steel washers are included.
 Weight per pair ~2.1g
 Thread
 Torx Fitting T25
 Material 7075 aluminum
