$19.55
Article number: 021-01-04
For specific fit needs where a wider pedal stance is required, KCNC’s Pedal Extenders enable extension of a pedal's spindle length. Manufactured from durable steel and available in three different lengths, these extenders work by threading onto your pedal's threads in order to space the pedal farther out from the crankarm. Available in three sizes, 18mm, 23mm, and 28mm, these pedal extenders are sold individually to allow maximum customization between left and right pedals. The extenders use a 9/16” thread standard, and feature 17mm wrench flats for installation onto the pedals. After removing the pedals from the bicycle, you simply thread the extenders onto your pedals, then reinstall the pedals and extenders back onto the crank.
After removing your pedals from the bicycle, you simply thread the extenders onto your pedals, then reinstall the pedals and extenders back onto the crank. Please note that these are compatible with pedals that are installed using either outboard wrench flats for use with a pedal wrench or a 6mm or smaller internal allen/hex wrench interface.
If your current pedals use anything larger than an internal 6mm hex (and does not have any pedal wrench flats), they will not be compatible with these extenders.
If you have 6mm internal hex/allen interface only, the included insert must be used, anything under 6mm will not require the insert. Please contact us with any fitment or installation questions.
Weight
18 mm 23 mm 28 mm 6 mm insert
~27g (per side) ~32g (per side) ~35g (per side) ~2g
 Pedal Thread Compatibility 9/16"
 Material Steel
 Compatibility 15 mm pedal wrench or 6mm hex wrench or smaller
