KCNC QR Rear Thru Axle
$100.00
$65.00
* Unit price: $65.00 /
Article number: 022-01-03
KCNC's handsomely machined, and exceptionally light rear 12 x 142 mm thru axle skewer. CNC machined from 7075 aluminum and hard anodized for durability that can withstand the rigors of typical mountain bike abuse. The hollow axle uses the already popular and proven ball and socket joint to close the lever that all other KCNC skewers use, insuring an iron grip on your dropout. Add a dash of color to your build while simultaneously shaving weight.
COMPATIBILITY
These 12 x 142 mm quick release thru axles are designed to be compatible with the Syntace X12, Shimano E-Thru or RockShox Maxle standards. Please purchase accordingly.
For complete sizing details on all of our thru axles please look HERE.
Model Interface Length Pitch Thread Length Weight
DT Swiss (X12) Tapered 160 mm 12 x 1.0 mm 15 mm ~49g
E-Thru Flat 170 mm 12 x 1.5 mm 15 mm ~44g
Rock Shox/Maxle Flat 172 mm 12 x 1.75 mm 21 mm ~47g
 Material 7075 Aluminum
 Hub Compatibility T/A 12 x 142
 Recommended Torque 10Nm
