KCNC SRAM Derailleur Cable Pulley
$12.00
Article number: 14-02-00
KCNC SRAM Derailleur Cable Pulley is a lightweight 7075 aluminum replacement cable guide pulley for select SRAM X01, XX1, X01 Eagle, and XX1 Eagle rear derailleurs. It replaces the factory plastic cable pulley used to route the rear shift cable between the derailleur cable stop and pinch bolt.
SRAM’s original plastic cable pulley can wear or develop grooves over time as the shift cable moves across it. KCNC’s machined aluminum version gives riders a more durable replacement part while keeping weight low at approximately 3.5 grams.
Compatibility Note: This part is for select SRAM mechanical mountain rear derailleurs only. Confirm that your derailleur uses the same rotating cable pulley design before ordering.
KCNC SRAM Derailleur Cable Pulley Compatibility
Specification
 Compatibility SRAM X01, XX1, X01 Eagle, XX1 Eagle Rear Derailleurs
 Application Rear Derailleur Cable Pulley / Cable Guide Replacement
 Material 7075 Aluminum
 Weight ~3.5 g
 Finish Black Anodized With White Logos
Why Replace The Stock Cable Pulley?
The derailleur cable pulley controls the cable path as the shift cable routes around the rear derailleur body. When the original plastic pulley becomes worn, grooved, or damaged, shifting can become harder to tune consistently. KCNC’s aluminum replacement is a small service part that can help restore a cleaner cable path on compatible SRAM derailleurs.
For other drivetrain service parts, pair this with fresh shift cable, housing, ferrules, and compatible SRAM derailleur hardware when refreshing a worn mechanical drivetrain.
