King Cage Lowering Bottle Cage
Article number: | 010-01-07 |
The Bottle Lowering Cage is a problem-solver that is otherwise identical to King Cage's standard lightweight titanium and affordable stainless steel bottle cages. The mounting tabs are 28mm (1.1") offset to allow a lower mounting position to increase bottle clearance on small frames or where space is otherwise restricted. Both the titanium and stainless steel cages offer excellent strength, durability, and corrosion resistance, and are suitable for any riding discipline. At a scant 28 grams, the titanium version is nearly half the weight of the stainless steel version.
Each cage is handmade in Durango, Colorado, embodying flawless craftsmanship.
Titanium | Stainless Steel | |
Weight | ~32g | ~46g |
