Leap Components SRAM AXS Rear Derailleur Stealth Cage
Leap Components SRAM AXS Derailleur Stealth Cage is a lightweight replacement cage designed for SRAM Eagle AXS GX, X01, and XX1 rear derailleurs. 3D-printed in the Netherlands from carbon-reinforced polyamide, the Stealth Cage reduces drivetrain weight while maintaining stable chain control and clean shifting performance for modern wireless mountain and gravel drivetrains.
Pulley wheels are not included. This allows riders to pair the cage with pulley wheels that match their drivetrain goals. Browse compatible pulley wheel options here.
Compatibility Note: The Stealth Cage fits SRAM Eagle AXS GX, X01, and XX1 rear derailleurs only. It is not compatible with SRAM Transmission (T-Type), mechanical Eagle, or SRAM road AXS derailleurs.
Why Use The Leap Components SRAM AXS Derailleur Stealth Cage
For riders upgrading SRAM Eagle AXS drivetrains, replacing the stock derailleur cage is a straightforward way to reduce system weight and customize pulley choice. The Stealth Cage is designed to maintain chain stability while allowing a lighter and more customizable drivetrain configuration.
- Replacement cage for SRAM Eagle AXS GX, X01, and XX1 rear derailleurs
- 3D-printed carbon-reinforced polyamide construction
- Manufactured in the Netherlands
- Available in multiple cage lengths
- Sold without pulley wheels for customizable drivetrain builds
- Suitable for mountain, gravel, and mixed-terrain riding
A lightweight drivetrain upgrade for riders refining SRAM Eagle AXS rear derailleur performance while customizing pulley selection.
