$46.99
Article number: 004-01-02
This 3.2mm version is the thickest, most comfortable of the three DSP tape options. This version is recommended for gravel, cyclocross, and all-road disciples where a thicker tape can provide added comfort on rough terrain. Additionally, riders who enjoy longer rides or who simply desire slightly more cushion at the handlebars will benefit from this 3.2m tape.
Includes two rolls of tape, color-matched bar plugs, clamp cover strips, and premium finishing strips.
Weight per Roll 31 grams
Weight per 100cm 14.9 grams
Weight, Bar Plugs (pair) 19 grams
Roll Length 208 cm
Thickness (measured) 3.1 mm
Material polymer
