$55.00
Article number: 014-01-03
In terms of both comfort and performance, anywhere that your body touches the bike is of the utmost importance. That's why Specialized designed the Hover Alloy Handlebars to excel on both fronts. Starting with the construction, they're made from Premium Butted Aluminum for a nice overall weight and high rigidity. And for comfort, much of it boils down to fit. Along these lines, they feature a shallow drop & bend that's extremely comfortable, while they also have a 15mm rise to help accommodate a wide fit range. For added stability we've added 12 degrees of flare at the drop to give that wide stance.
 Width 38 cm 42 cm 42 cm 44 cm 46 cm
 C to C Hoods 38 cm 40 cm 42 cm 44 cm 46 cm
 C to C Drops 43 cm 45 cm 47 cm 49 cm 51 cm
 Weight ~ 302g ~ 304g ~ 309g ~ 313g ~ 315g
 Reach 70 mm
 Drop 103 mm
 Rise 15 mm
 Flare 12°
 Material 6061 Aluminum
