Specialized Roubaix Pro 2BR Tire
Article number: | 04-05-03 |
Availability: | In stock (4) |
The Roubaix Pro 2Bliss Ready is an endurance road tire that's well suited for smooth and rough roads alike. That's because it's fast like any competitive road tire, only it features a unique Endurant casing with bead-to-bead puncture protection and increased sidewall stability. The casing smooths your ride and keeps you fresh, while the tread handles responsively. Add to this the lower pressures and natural pinch-flat protection that tubeless setups provide, and you'll be hammering through corners confidently in no time.
Compound | GRIPTON® | |
Flat Protection | Endurant Casing and Black Belt | |
Casing | 120 TPI | |
Weight | Recommended Tire Pressure | |
700x30mm/32mm | 375 grams | PSI 45-90 |
