$89.00
Article number: 001-04-02
Delivery time: 3-5 days
SRAM RED Flattop Chain is designed for SRAM’s 12-speed road drivetrains using the distinctive Flattop chain profile. The narrower shape increases strength while allowing tighter drivetrain spacing for modern AXS systems.
Hard chrome-plated inner plates and rollers improve wear resistance, while HollowPin construction and machined outer plates reduce weight without compromising durability. The chain is supplied with a Flattop PowerLock for installation and service.
Waxed Chain Option
Our optional chain waxing service prepares the chain using a multi-step process that removes factory grease and replaces it with a high-performance wax coating. Waxed chains run quieter, stay cleaner, and typically require less frequent drivetrain cleaning.
  • Degreased and fully cleaned before waxing
  • Hot-wax treated using Molten Speed Wax
  • Wax cured and inspected before packaging
  • Quieter drivetrain operation with reduced contamination
  • Ideal for riders maintaining waxed drivetrain systems
Because the waxing process takes several days, riders often keep a second pre-waxed chain ready for rotation.
 Specification SRAM RED Flattop Chain
 Weight ~235 g (uncut / including PowerLock)
 Speed 12-Speed Road (Flattop)
 Includes Flattop PowerLock Link
 Version E1
 Wax Option Molten Speed Wax
Related SRAM Road Drivetrain Products And Waxing Resources
Pair this chain with compatible drivetrain components and maintenance products for a cleaner and more consistent road setup.
