$372.35
Article number: 012-01-03
White Industries CLD (Center Lock Disc) hubs are designed around the Center Lock splined rotor mounting interface as opposed to the 6-bolt mounting standard. Made from U.S. sourced 6061-T6 aluminum, they’re available in a range of drillings, colors, and axle configurations.
  • U.S. made 6061-T6 aluminum
  • Enduro bearings
  • 6/4 titanium driver
  • 3-pawl, 48 point (7.5 degree) engagement
  • Compatible with Center Lock style rotors
  • Rotor lockrings not included
  • Rotor lockring compatibility
    • Internally splined lockring such as Shimano SM-RT81
  • Cassette spacer included only on XDR freehub bodies
    • Available separately for Shimano HG11 (part# SPACER11)
Specs
  • 256g
  • Drillings: 24, 28, 32, 36
  • Axles:
    • 12mm x 142mm Thru
    • 10mm x 135mm QR
Bearings
  • All Enduro ABEC 5 except 3802W (ABEC 3)
Driver Style
Left hub shell bearing Right hub shell bearing Inner driver bearing
Outer driver bearing
Shimano Hyperglide 11 speed
61902-SRS 61902-SRS 3802W LLB
61902-SRS
Shimano Micro Spline
3802W LLB
SRAM XD/XDR
3802W LLB
Campy 11 speed
3802W LLB
Campy N3W/EKAR 13 speed
3802W LLB
Wheelbuilding specs
  • Spoke hole diameter
    • 2.6mm
Left Flange Diameter 45mm
Right Flange Diameter 55mm
Center To Left Flange 33mm
Center To Right Flange 19mm
