$126.00
Article number: 005-05-03
Abbey Bike Tools BBQ Pedal Wrench is designed to handle modern pedal installation and removal across a wide range of drivetrain setups. With both a traditional 15 mm pedal wrench and a 6 mm / 8 mm hex swivel bit, it allows mechanics to service pedals that install from either the wrench flats or the internal hex interface.
The BBQ wrench is available in two versions. The Team Issue Pedal Wrench is a lightweight travel-focused version with weight-reducing pockets, while the Shop Pedal Wrench provides additional length for improved leverage when removing stubborn pedals.
Why Use Abbey BBQ Pedal Wrench
Modern pedals often require either a traditional 15 mm wrench or an internal hex key for installation and removal. The BBQ Pedal Wrench combines both interfaces in a single tool, allowing mechanics to remove and install pedals quickly whether working in a workshop, race environment, or travel toolkit.
  • 15 mm pedal wrench for traditional pedal flats
  • Integrated 6 mm and 8 mm swivel hex bit for internal pedal interfaces
  • Team Issue version optimized for lighter travel toolkits
  • Shop version provides additional leverage for stubborn pedals
  • White oak handle provides comfortable grip during pedal service
  • Designed for professional workshop, race, and travel maintenance
 Specification Team Issue Shop
 Material Chromed Steel Chromed Steel / Black Cerakote
 Handle White Oak
 Included Tools 15 mm Pedal Wrench & 6 / 8 mm Swivel Hex
 Length 30 cm / 11.75 in 35 cm / 13.75 in
 Weight ~325 g ~453 g
Pairs Well With
For broader drivetrain service, the BBQ Pedal Wrench pairs well with the Abbey Crombie Cassette Lockring Tool and the Abbey Decade Chain Tool, two commonly used tools for cassette and chain service.
