$205.00
Article number: 005-05-04
Abbey Bike Tools H.A.G. (Hanger Alignment Gauge) is a precision alignment tool designed to restore proper derailleur hanger alignment on modern geared bicycles. As drivetrains have advanced from 8-speed systems to 12- and 13-speed setups, accurate hanger alignment has become critical for reliable shifting, reduced drivetrain noise, and consistent indexing.
Precision machined for strength and repeatability, the H.A.G. is designed to measure and correct bent derailleur hangers across a wide range of bike types, including road, mountain, commuter, and full suspension bikes. Its adjustable design and rigid construction make it suitable for both professional workshop use and serious home mechanics.
Why Use Abbey H.A.G.
Bent derailleur hangers are one of the most common causes of poor shifting. The H.A.G. is designed to provide accurate derailleur hanger alignment measurement and controlled correction, allowing mechanics to resolve indexing problems at the source instead of chasing adjustment issues elsewhere in the drivetrain.
  • Designed for precise derailleur hanger alignment and correction
  • Helps resolve poor shifting caused by bent hangers
  • Adjustable design supports many bicycle types and wheel sizes
  • Rigid construction allows controlled correction of stubborn hangers
  • Suitable for professional workshop and home mechanic use
  • Works as the primary alignment tool in the Abbey alignment tool system
  • Diagnosing shifting problems caused by hanger misalignment
  • Correcting derailleur hangers after crashes or transport damage
  • Routine drivetrain setup and alignment checks
  • Workshop service for modern multi-speed drivetrains
 Specification
 Material Stainless Steel / Aluminum
 Wheel Compatibility 26 in, 27.5 in / 650b, 700c / 29 in
 Tool Length 11 in / 28 cm
Alignment Tool System
The H.A.G. is the primary precision tool in Abbey’s alignment workflow. For quick visual checks before full correction, pair it with the Abbey preHAG. For consistent brake and shift lever positioning across different handlebar shapes, pair it with the Abbey Lever Setter.
Pairs Well With
For alignment-focused setup work, the H.A.G. fits naturally with the Abbey preHAG and the Abbey Lever Setter. For broader drivetrain service after alignment correction, it also works well alongside the Abbey Decade Chain Tool.
