Ashima Rotor Bolt Set
| Article number: | 007-04-02 |
The Ashima Rotor Bolt Set provides reliable rotor fastening in two material options—7075 aluminum for low weight and steel for maximum durability. Both variants use standard M5 × 10 mm threads and Torx drive heads for secure installation. Aluminum sets include 6 bolts for a single rotor; steel sets include 12 bolts for two rotors, supporting road, gravel, and MTB use. Use a medium‑strength threadlocker and torque to your brake manufacturer’s specification (commonly ~4–6 Nm).
Aluminum (7075):
~6.5 g per set (one rotor)
T20 Torx head
optimized for weight‑conscious builds and XC/light‑duty
applications up to 160 mm rotors.
Steel:
~24 g per set of 12 (two rotors)
(~12g per rotor(6pcs))
T25 Torx head
best for long‑term durability and larger rotors.
Fit & Use
Rotor standard: 6‑bolt ISO rotors
Thread: M5 × 10 mm (fits most 6‑bolt hubs/rotors)
Always follow hub/rotor maker torque specs; apply medium threadlocker; tighten in a star/alternating pattern.
| Aluminum - Sold In Set Of 6 | |
| Weight | ~6.5g (Set) |
| Material | 7075 Aluminum |
| Thread | M5 x 10 mm |
| Tools | T20 Torx |
| Colors | Black / Blue / Gold / Red |
| Steel - Sold in set of 12 | |
| Weight | ~24g (Set of 12 bolts) |
| Material | Steel |
| Tools | T25 Torx |
