Ashima Disc Brake Adapter Series
Article number: | 007-04-03 |
The Ashima Disc Brake Adapter Series provides precision-machined solutions for adapting disc brake calipers across a wide range of mount standards and rotor sizes. Whether converting a flat-mount road frame to use a post-mount caliper, spacing a post-mount to fit larger rotors, or adapting between IS and post-mount interfaces, Ashima offers a lightweight and durable option for every setup.
Each adapter is CNC-machined from aluminum alloy for strength and accuracy, ensuring proper rotor alignment and secure caliper positioning. Designed for road, gravel, mountain, and cyclocross bikes, these adapters cover rotor sizes from 140 mm to 180 mm. All mounting hardware is included for straightforward installation.
ORDERING
Adapters are specific to front and rear brakes and rotor diameter. Please take care when ordering to ensure you receive the correct adapter.
Frame / Fork Compatibility | Flat Mount | |||
Caliper Compatibility | Post Mount Caliper | |||
Fits | Compatibility | Weight | ||
AU41 | Front - 140 mm Rotor | ~57g | ||
AU43 | Rear - 140 mm Rotor | ~41g | ||
AU42 | Front - 160mm Rotor | ~70g | ||
AU44 | Rear - 160mm Rotor | ~50g | ||
Frame / Fork Compatibility | I.S. Mount | |||
AU01 | Front - 160 mm Rotor | ~22g | ||
Rear - 140 mm Rotor | ||||
AU02 | Rear - 160 mm Rotor | ~27g | ||
AU03 | Front - 180 mm Rotor | ~32g | ||
AU04 | Rear - 180 mm Rotor | ~39g | ||
Material | Aluminum (Steel Bolts) |
