Ashima Disc Brake Pads
| Article number: | 007-04-05 |
The Ashima Disc Brake Pad Series provides reliable replacement pads for a wide range of braking systems. Available in organic or semi-metallic compounds, Ashima pads are engineered for balanced stopping power, predictable modulation, and low noise across road, gravel, cyclocross, and MTB use.
Each pad set includes pad springs and is designed to match OEM shapes for Shimano, SRAM, Avid, Hope, Tektro, Magura, and other popular disc brake calipers. Ashima’s precision-manufactured compounds and backing plates ensure consistent wear rates and reliable braking in wet or dry conditions.
- Available in organic (quiet, high modulation) or semi-metallic (durable, higher bite)
- Direct-fit replacement for Shimano, SRAM, Avid, Hope, Magura, Tektro, and others
- Includes pad springs where required Balanced performance for road, gravel, CX, and MTB
- Designed for consistent stopping power in varied riding conditions
| Weight | ~20g (Pads and Springs) |
| Material | Organic or Semi-Metallic |
| Includes | Heat Dissipation Channels / Springs |
| Compatibility | Shimano / Rever / Tektro / Avid / SRAM |
| AD0107 | |
| Shimano | XTR M9110 / M9100 - Dura Ace R9270 / R9170 - XT M8110 - Ultegra R8170 / R8070 - 105 R7070 - Tiagra BR-4770 / GRX RX810 / RX400 - RS805 / RS505 / RS405 / RS305 - Metrea U5000 |
| Tektro | HD-R350 / R310 - R802(Front) - EU810(Front) - R811(Front) |
| TRP / REVER / Riderever | HD-T910 - MCX1 Flat Mount - Attack-U(FM) / S(FM) - MCX2 |
| AD0707 | |
| Avid | Red |
| SRAM | HRD eTap Level Ultimate / TLM |
