Far And Near Titanium Rotor Bolts
$50.00
Article number: 28-04-05
Far and Near Titanium Rotor Bolt Set is a lightweight upgrade for any 6-bolt disc brake system, replacing standard steel hardware with precision-machined 6/4 titanium bolts. Designed for performance-focused builds, this 12-bolt set secures two rotors while reducing rotational weight by approximately 15 grams compared to traditional steel bolts.
Titanium construction provides an excellent balance of strength, corrosion resistance, and weight savings, making these bolts ideal for road, gravel, and MTB applications where reliability and performance matter. Each bolt uses a T25 Torx interface for secure installation and consistent torque application.
  • Weight-conscious road, gravel, and MTB builds
  • Upgrading OEM steel rotor bolts to titanium
  • Reducing rotational weight for improved efficiency
  • Custom builds where premium hardware matters
  • Riders prioritizing corrosion resistance and longevity
Installation Notes
Install using a T25 Torx tool and tighten bolts in a star pattern to ensure even rotor seating and proper alignment. Always follow the torque specifications provided by your rotor manufacturer. Using a torque wrench is recommended for consistent and safe installation.
 Bolt Thread M5 x 10 mm
 Weight ~11 g (Per Wheel)
 Material 6/4 Titanium
 Interface T25 Torx
 Compatibility Standard 6-Bolt Disc Rotors
Pairs Well With
Complete your braking setup with high-performance components and tools:
For full system optimization, consider upgrading both rotors and hardware together to reduce weight and improve braking consistency.
