Ashima Rite Toolz Hydraulic Brake Tool
$25.00
* Unit price: $25.00 /
Article number: 007-06-04
The Hydraulic Hose Cutter delivers clean, square cuts on any size hydraulic hose with its sharp cutting blade, ensuring optimal sealing and connection. Made from durable plastic, it is lightweight yet robust enough for regular workshop use.
The Hydraulic Fitting Press simplifies and standardizes barb and banjo fitting installation. Its CNC-machined aluminum body and stainless-steel barb holder ensure long-term accuracy, while the compact form factor (85 × 65 × 35 mm, ~146 g) makes it easy to use in tight workspaces. The dual-function design preps freshly cut hoses and presses barbs straight and true every time—essential for reliable hydraulic brake performance.
When paired together, these tools streamline brake line preparation and ensure professional-grade results for mechanics and home builders alike.
Hydraulic Hose Cutter:
Precision blade for clean, square hose cuts
Fits all hydraulic hose diameters
Lightweight and durable plastic construction
Hydraulic Fitting Press:
CNC-machined aluminum body with stainless-steel barb holder
Compatible with barb and banjo fittings
Dual-function design: hose prep + barb installation
Compact dimensions: 85 × 65 × 35 mm
Weight: ~146g
Hydraulic Brake Hose Fitting Press
 Material Aluminum / Stainless Steel
 Hose End Compatibility Barb / Banjo
 Dimensions 85 mm x 65 mm x 35 mm
 Weight ~146g
Hydraulic Brake Hose Cutter
 Material Plastic
For a complete brake service setup, pair this toolset with the Ashima Reaction Hydraulic Hose Kit or check out the Alligator Hydraulic Hose Tools.
