Bjōrn Sedlo Saddle
$330.00
Article number: 011-05-06
Björn Sedlo Saddle is a full carbon saddle built for riders who want an exceptionally light platform without giving up real-world comfort. At approximately 89g, Sedlo is shaped to be ridden without padding or a top cover, allowing smooth position changes and a direct, responsive feel.
The carbon shell is engineered with a slight amount of controlled flex to help reduce harsh road vibration, while the reinforced underside structure adds strength without unnecessary mass. A central cutout improves pressure relief and helps keep riders and bibs drier on long rides, making Sedlo a purpose-built option for high-performance road and gravel setups.
With its clean, uncovered carbon surface and minimalist design, Sedlo fits naturally into lightweight builds centered around Björn Cycles components and other premium performance parts.
  • Full carbon saddle designed for ultralight performance builds
  • No padding or top cover for direct feel and easy rider movement
  • Slight shell flex helps reduce harsh road vibration
  • Central cutout improves pressure relief and moisture management
  • Reinforced underside structure for strength without excess weight
  • 7 x 9 mm carbon rails for use with compatible saddle clamps
Ideal for riders building an ultralight road, climbing, or weight-conscious gravel bike who prefer a firm, direct saddle feel. Sedlo is best suited to cyclists comfortable with a minimalist saddle platform and looking to save meaningful weight without moving to a compromised shape.
Its slick uncovered surface also benefits riders who shift position frequently during hard efforts, climbing, or aggressive riding. For the right rider, Sedlo delivers low weight, clean aesthetics, and surprisingly usable comfort in a pure carbon format.
Fit Notes
This saddle uses 7 x 9 mm carbon rails, so your seatpost clamp must be compatible with oversized oval carbon rails. The uncovered shell is intended to be ridden as designed, with the carbon structure itself providing the riding surface.
Specification
 Material Carbon
 Padding None
 Weight ~89 g
 Length 250 mm
 Rail To Saddle Top 23 - 34 mm
 Saddle Rail 7 x 9 mm
 Rider Weight Limit 120 kg / 260 lbs
Cross-Linking Suggestions
Complete a lightweight build with other Björn Cycles components, or pair the Sedlo with premium lightweight seatpost and cockpit upgrades for a cohesive high-performance setup.
