Bjōrn Sedlo Saddle
$330.00
Article number: 011-05-06
Björn Sedlo Saddle is a minimalist full carbon saddle designed for riders prioritizing extremely low weight and direct ride feel. At approximately 89g, Sedlo is intended to be ridden without padding or a top cover, allowing unrestricted movement and a clean interface between rider and bike.
The carbon shell incorporates a controlled amount of flex to help reduce harsh road vibration, while the reinforced underside structure improves strength without unnecessary mass. A central cutout aids pressure relief and moisture management during longer rides and high-output efforts.
Unlike Björn’s Kort and Setka models, Sedlo eliminates printed padding entirely in favor of the lightest and most direct saddle platform in the Björn lineup.
  • Minimal full carbon saddle for ultralight builds
  • No padding or top cover for direct rider feedback
  • Controlled shell flex helps reduce harsh vibration
  • Central cutout improves pressure relief and moisture management
  • Reinforced underside structure for improved durability
  • 7 x 9 mm carbon rails for compatible oversized saddle clamps
  • Approximate weight of 89g
Best suited for riders comfortable with a firm, highly direct saddle feel and looking to minimize weight without moving to an extreme or compromised shape. Sedlo works especially well for climbing bikes, lightweight road builds, and weight-conscious gravel setups.
Its uncovered carbon surface also benefits riders who frequently shift position during climbing, sprinting, and aggressive riding efforts.
Fit Notes
This saddle uses 7 x 9 mm carbon rails and requires a compatible seatpost clamp for oversized oval rails. Sedlo is designed to be ridden directly on the exposed carbon shell without additional cover material or padding.
Product Details And Saddle Comparison
Specs Sedlo Divan
 Saddle Type Minimal Full Carbon Padded Performance
 Ride Feel Direct / Firm More Dampened / Supported
 Padding None Foam Padding
 Weight ~89 g ~127 g
 Length 250 mm 250 mm
 Rails 7 x 9 mm
 Rider Weight Limit 120 kg / 260 lbs 120 kg / 260 lbs
 Best Use Ultralight Road / Gravel Road / Gravel / Cyclocross
Cross-Linking Suggestions
For riders wanting additional support and vibration damping, compare the Björn Kort Saddle or Björn Setka Saddle, both featuring 3D-printed support structures.
For more traditional padded options, consider the Björn Probka Cork Saddle or upcoming Björn Divan Saddle.
