Bjōrn Divan Saddle
| Article number: | 011-05-06 |
Björn Divan Saddle is a lightweight padded performance saddle designed to balance long-ride support, vibration damping, and efficient power transfer across road and gravel riding. Using a carbon shell, oversized carbon rails, and a traditional foam-padded structure, Divan delivers a more familiar ride feel than Björn’s exposed carbon or 3D-printed saddle options while remaining performance focused.
The compact profile and pressure-relief channel are intended to support aggressive riding positions without excessive bulk, while the padded upper structure helps reduce fatigue during longer rides and rougher terrain.
Compared to the Björn Sedlo Saddle, Divan prioritizes additional support and vibration management over absolute weight reduction.
- Lightweight padded carbon saddle for road and gravel riding
- Traditional foam-padded structure with carbon shell
- Pressure-relief center channel for improved comfort during long rides
- Compact performance-oriented saddle profile
- Oversized 7 x 9 mm carbon rails
- Balanced support and vibration damping for mixed terrain use
- Available in multiple saddle widths
Divan is best suited for riders wanting a more traditional padded saddle feel while still maintaining a lightweight, performance-oriented setup. It works especially well for road endurance riding, gravel riding, mixed terrain, and longer-distance efforts where additional damping and support improve overall ride quality.
Compared to Björn’s more minimal saddle options, Divan sacrifices some weight in exchange for improved comfort and reduced harshness over longer rides.
Fit Notes
Divan uses oversized 7 x 9 mm carbon rails and requires a compatible seatpost clamp for oval carbon rails. Multiple width options allow riders to better match saddle support to riding position and sit bone width.
Product Details And Saddle Comparison
| Specification | Divan | Sedlo |
| Saddle Type | Padded Performance | Minimal Full Carbon |
| Padding | Foam Padding | None |
| Weight | ~127 g | ~89 g |
| Length | 250 mm | |
| Width Options | 143 mm | 143 mm / 155 mm |
| Rails | 7 x 9 mm | |
| Rider Weight Limit | 120 kg / 260 lbs | |
| Best Use | Road / Gravel / Cyclocross | Ultralight Road / Gravel |
Cross-Linking Suggestions
For riders wanting the lightest and most direct saddle feel possible, compare the Björn Sedlo Saddle.
For 3D-printed saddle options, view the Björn Kort Saddle or Björn Setka Saddle. Riders wanting a natural-material padded option should consider the Björn Probka Cork Saddle.
