$440.00
Björn Kort Saddle is a short-nose carbon saddle with a 3D-printed multi-zone pad, built for riders using aggressive road, gravel, triathlon, or TT positions. At approximately 117g, Kort combines a carbon shell, reinforced rail interface, and printed support structure in a compact platform designed for forward-rotated riding.
The shorter 220mm length and wider front support area help reduce inner thigh interference while improving stability under load. Compared to Björn’s longer Setka 3D-printed saddle, Kort is the better choice for riders who spend more time in aero or aggressive positions.
  • Short-nose carbon saddle with 3D-printed multi-zone pad
  • Optimized for aggressive road, gravel, triathlon, and TT positions
  • Compact shape reduces inner thigh interference near the nose
  • Wider front platform improves support in forward-rotated positions
  • Carbon shell with reinforced rail interface
  • Oversized 7 x 9 mm carbon rails
  • Approximate weight of 117g
Kort is best for riders who prefer a short-nose saddle and spend meaningful time in a forward, aggressive position. It is especially useful for road racing, triathlon, TT, and performance gravel setups where stability near the front of the saddle matters.
Product Details And Saddle Comparison
Specs Kort Setka
 Saddle Type Short Nose Traditional Length
 Weight ~117 g ~137 g
 Length 220 mm 250 mm
 Nose 40 mm 37 mm
 Rails 7 x 9 mm
 Shell Carbon
 Pad 3D-Printed Multi-Zone 3D Printed
 Weight Limit 120 kg / 264 lbs
 Best Use Aero Road, Triathlon, TT Road, Gravel, Endurance, XC
Cross-Linking Suggestions
Compare Kort with the Björn Setka Saddle for a longer 3D-printed saddle shape designed around more traditional road and gravel positions.
For a more minimal ultralight setup, view the Sedlo Saddle. For riders who prefer padding, compare the Probka Saddle or the upcoming Divan Saddle.
