Cane Creek 110 Lower Headset Assembly
| Article number: | 005-03-01 |
Experience the precision of the Cane Creek 110 Headset, showcasing exceptional craftsmanship. Outperforming with double shielded bearings and a unique double lip seal on the crown race, it excels in durability. The External Cup version features a machined slot with an o-ring for added resilience. Opt for longevity, user-friendly maintenance, and easy part replacement – the ideal choice for rugged rides.
For headset inquiries, reach out to us or consult Cane Creek's S.H.I.S. guide for guidance on the ideal headset for your needs.
| Headset | Weight | SHIS | Stack | Bearings | ||
| IS 47/33 | ~35.5g | Integrated 47mm / 33mm Crown Race | 1mm | Black Oxide 45 / 45° | ||
| EC 44/33 | ~57g | External Cup 44mm / 33mm Crown Race | 12mm | Black Oxide 45 / 45° | ||
| IS 52/40 | ~34.5g | Integrated 52mm / 40mm Crown Race | 1mm | Stainless 36 / 45° | ||
| EC 44/40 | ~54.5g | External Cup 44mm / 40mm Crown Race | 12mm | Stainless 36 / 45° | ||
| EC44/33 | Uses a 47mm bearing | |||||
| EC44/40 | Uses a 52mm bearing | |||||
| EC49 | Uses a 52mm bearing | |||||
| IS41 | Uses a 41mm bearing | |||||
| IS52 | Uses a 52mm bearing | |||||
| ZS44 | Uses a 41mm bearing | |||||
| ZS56 | Uses a 52mm bearing | |||||
