$60.00
Article number: 003-01-01
Craig’s tool was designed for roadies by a roadie that likes to carry the tools really needed, not the kitchen sink. It’s perfect for those that demand the useful shape of the time-proven Allen key and like to keep things light weight and simple.
The Bits are double ended and are held by a magnet in the handle socket. With the fiber reinforced nylon bit caddy clipped to the L handle, there are 4 sockets to hold 3 bits, so there is always a spare place for the bits as they are moved to the desired location. This makes for easy bit change on the road without fumbling and dropping bits. The Tool weighs 32 grams and the plug repair kit is 6 grams making it incredibly light!
The Tool uses the highest quality materials. The handle is made from high strength aluminum, the bits are made from 440C heat treated stainless steel and the Tire Repair Plug Kit is made of 6/4 Titanium. The tool is compact and stores easily in any tool bag.
  Multi Tool Plug Tool
 Weight ~32g ~6g
 Material Aluminum / Stainless Steel 6/4 Titanium
  Included
 Multi Tool L-handle Tool
  2.5 mm / 3 mm / 4 mm / 5 mm / 6 mm / T25 Torx
  Nylon Bit Cady
 Plug Tool 15 tire plugs
